Hello,
I’m experiencing an issue with my portal login setup. Initially, the portal would display both the admin and agent fields for entering the username and password, along with a "Looking for the Client Portal?" message, directing users to the URL: https://domain/login.php.
However, after logging off recently, I noticed that the URL now automatically redirects me to the client portal login: https://domain/client/login.php.
I suspect that I may have accidentally changed a configuration setting that’s causing the admin login portal (https://domain/login.php) to redirect to the client portal. Can someone point me in the right direction on where I might have made the change, or how I can fix it?
Thanks in advance for your help!
